Help with hydraulic winch for splitter build
   / Help with hydraulic winch for splitter build #1
Roehm Farms
Hillsboro, Ohio
JD 4310
I Just purchased a craigslist project to finish. As it sits it is a trailer mounted splitter with a 3.5" x 32" cylinder mounted on a light beam with a fixed wedge. It also came with a 4.5"x 32" or 34" cylinder. Right now none of the hydraulics are hooked up and there is no motor. The trailer has a boom mounted and the previous builder was planning to switch the cylinders and use the 3.5" on the boom.
My plan is to use this on my jd 4310, 8.6 gpm flow and 2500psi, for now and maybe eventually turn it into a 3ph splitter.
So now on to my questions,
I would like to build a light duty hydraulic winch to use on the boom instead of the lift cylinder, so I can drag cut pieces (up to 150lbs) up to 25' away to the splitter. I am planning to use a hydraulic wheel motor https://www.surpluscenter.com/Hydraulics/Hydraulic-Motors/Wheel-Mount-Hydraulic-Motors/28-3-cu-in-HYD-WHEEL-MOTOR-W-5-BOLT-HUB-9-8092.axd with a 8" wheel for the winch. For the hydraulic experts what can I expect out of the wheel motor with my 8.6 gpm flow?
For control, I have two options planned out, either a electric valve control with a remote https://www.surpluscenter.com/Hydraulics/Hydraulic-Valves/Solenoid-Valves/12-VDC-5-GPM-OC-MOTOR-SPOOL-HYDRAFORCE-SOL-VALVE-9-7988.axd after the single spool splitter valve. Or a double spool splitter valve with the lines to the winch tee'd with a ball valve in between so I can free spool the winch out. Any recommendations on which way to plan this?
Thank you for looking,
Jeff
   / Help with hydraulic winch for splitter build #2
Welcome from Wisconsin
Thank you
I forgot that part, long time reader, first time poster, and I did search before I posted. There are some awesome splitter and everything else builds on this site.
-Jeff
   / Help with hydraulic winch for splitter build #4
Your motor speed at 8.6 GPM will by about 70.
Torque about 11,266 lbs using 2500 psi.
Your log slitter valve will have to have PB to add the solenoid valve.
You could add the solenoid before the log splitter valve and use a regular log splitter valve.
The solenoid valve will give you full flow all the time.
You can't tee open center valves. They must be in series.
You could use a valve with float and be able to pull the winch cable.
Thanks J_J
70rpm with an 8" wheel/winch spool (25" circumference) ~72 Feet per minute just under 1mph would be plenty fast and likely need slowed down. The electric winch I was looking at is 13fpm. So I may need a flow control with the electric solenoid.
Wasn't planning on teeing the valves, I was thinking about putting Tees in the lines between the valve and wheel motor with a ball valve in between the two lines to provide a bypass, open the ball valve to freewheel the motor.
Thanks again, Jeff
Here is what I'm working with. I picked up some hoses today, it does work.
   / Help with hydraulic winch for splitter build #7
You are correct in saying that there are some great builds on here. My question would be is the 150 pound log going to come to you or is the trailer /splitter going to tip and go to the log? I would use the larger cylinder on the splitters beam, as my 4 inch seems small on larger knotty pieces. you could cut the speed by using a two part line to your log. Pulley would have tongs on it,(or chain) with the end being hooked back on lifting beam. You have a nice starting point for your build. How are you going to mount the 4-way splitter? Catch table ?
   / Help with hydraulic winch for splitter build #8
Or, you could go to TSC and get an atv winch and mount on your boom and use a long control cord to operate the winch.
Thanks guys
2458n, the trailer is plenty heavy, but I see your point, also why am thinking it may be turned into a 3point. I would be worried a double line would get tangled to easy. I was pretty impressed with what how it did with the 3.5" cylinder but didn't really try any notty stuff.
Muddstopper, I have looked at them this one is a lot cheaper then what I am looking at 2500 lb. Electric ATV/Utility Winch with Wireless Remote Control but then a need a battery and charger in the mix also.
   / Help with hydraulic winch for splitter build #10
Jeff
I assumed you had already planned a battery and charger as they would be needed for a 12v solenoid valve.
I use a small 1000lb truck crane with electric winch on my splitter. My 25hp kholer has electric start and I use a marine battery for the starter and to operate the winch. I did make my own control cord for the winch. Control cord is about 20ft long, this lets me pull the cable to the round, hookup and winch back to splitter. Any hydraulic system with a manual control valve would necessitate actually staying within arms reach of the control valve in order to operate the winch. I use log tongs to attach to the round and sometimes they slip off while winching. No problem with the electric winch since i am still standing next to the round and can easily rehook. I suspect a manual hydraulic winch would mean a lot of walking back and forth between the round and the control valve. If I was going to use a hydraulic winch, I believe i would opt for the 12v solenoid valves with a remote or long control cord before I would use the manually controlled valves. I also believe I prefer to just run the cable off the winch over free spooling. If i was having to drag anything over 20ft, free spooling the winch cable might save a few seconds, but then you would still have to walk back to the machine to close the ball valve before you could winch the round. I guess it really depends on just how far you need to winch your wood.
Unused 2025 Wolverine SBM-12-72W Sickle Bar Mower Skid Steer Attachment (A51691)
Unused 2025...
2008 Honda Pilot SUV (A53117)
2008 Honda Pilot...
2025 Mower King ECSSTR072 (A50123)
2025 Mower King...
40ft Sea Container (A52384)
40ft Sea Container...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
2003 Peterbilt 330 T/A Progress A90LS 4,500 Gallon Fuel Truck (A51692)
2003 Peterbilt 330...
