Help with hydraulic top link...JD.
   / Help with hydraulic top link...JD. #1
Fuddy1952
Elite Member
South Central Virginia
1973 Economy and 2018 John Deere 3038E
I have a 3038E I got a hydraulic top link and spool valve. Pictures show what I have, need installation help. First picture shows valve has 5 ports plus an adjustment of some sort.
1 is marked T, 2 is marked N, 5 is marked P.
3&4 on top are unmarked.
Next picture is valve.
Tractor rear top disconnect line goes to tractor front, I assume pump? Marked "1" in picture. I removed backhoe today so flexible hose (return to tank) is "2". I plugged this hose into "1" now.
Am I pointing to the pressure adjustment under seat near draft control?
   / Help with hydraulic top link...JD. #5
Just speculating without looking at the specs on the valve...the 'P' is pressure in...the 'T' is the return to tank and the 'N' is the power beyond port...
The two ports on top are the working ports that will go to the top link...
275 Gallon Fuel Tank (A50775)
275 Gallon Fuel...
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2021 KENWORTH T270 (A55745)
2021 KENWORTH T270...
2001 Club Car DS 6 Passenger 48V Electric Golf Cart (A55758)
2001 Club Car DS 6...
Bigfoot Metal Stand Up Sign (A55758)
Bigfoot Metal...
