Help with hydraulic top link...JD.
   / Help with hydraulic top link...JD. #1
Fuddy1952
Elite Member
South Central Virginia
1973 Economy and 2018 John Deere 3038E
I have a 3038E I got a hydraulic top link and spool valve. Pictures show what I have, need installation help. First picture shows valve has 5 ports plus an adjustment of some sort.
1 is marked T, 2 is marked N, 5 is marked P.
3&4 on top are unmarked.
Next picture is valve.
Tractor rear top disconnect line goes to tractor front, I assume pump? Marked "1" in picture. I removed backhoe today so flexible hose (return to tank) is "2". I plugged this hose into "1" now.
Am I pointing to the pressure adjustment under seat near draft control?
   / Help with hydraulic top link...JD. #5
Just speculating without looking at the specs on the valve...the 'P' is pressure in...the 'T' is the return to tank and the 'N' is the power beyond port...
The two ports on top are the working ports that will go to the top link...
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
2025 Swict 66in Bucket Skid Steer Attachment (A55787)
2025 Swict 66in...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2018 KENWORTH T880 DAYCAB (A55745)
2018 KENWORTH T880...
CAT Skid Steer (A50322)
CAT Skid Steer...
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
