help with heater hose connection
   / help with heater hose connection #1
Dirtnut
North Central, Pa. USA
Kioti LK3054w/cab
i have an 02 lk3054 that i built a cab for (cab project-build it yourself forum) i ordered a heater & valve kit for it but i am not sure what the best way is to tie into the radiator. i cannot find tees for the 1-5/16" radiator hoses.will i have to make my own out of pipe & weld a fitting into it.also does the bottom hose get the shut off valve to the heater.
   / help with heater hose connection #2
you need to go into the block with you hoses the radiator temp will not stay the same enough for a heater
   / help with heater hose connection #3
Dirtnut
the pages at the back of this pdf might help
todd k
  • Mounting Instructions John Deere 221.pdf
   / help with heater hose connection #4
If anyone is looking for a radiator hose tee, look up JTR in Google. They sell many different sizes.
Thanks for the info. I did manage to make a tee out of pipe & brass fittings they seem to be working but if they fail i will need to do something different. thanks again.
   / help with heater hose connection #6
I just purchased a 1-1/4 inline radiator hose heater for my LK. Seems to fit fine on the bench and 1-1/2 was to big. I hope I don't run into trouble with the 1-1/4 versus the 1-5/16.
Joel
what are you going to use the tees for.
11' CONTAINER (A52706)
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
1992 Ford L900 Cab Chassis with Low Milage Cummins (A56435)
1992 Ford L900 Cab...
LOT: (3) Shelves of Parts, Filters, Oil, Antifreeze (CONTENTS ONLY - ALL APPEAR TO BE UNOPENED) (A59076)
LOT: (3) Shelves...
