help with heater hose connection
   / help with heater hose connection #1
Dirtnut
North Central, Pa. USA
Kioti LK3054w/cab
i have an 02 lk3054 that i built a cab for (cab project-build it yourself forum) i ordered a heater & valve kit for it but i am not sure what the best way is to tie into the radiator. i cannot find tees for the 1-5/16" radiator hoses.will i have to make my own out of pipe & weld a fitting into it.also does the bottom hose get the shut off valve to the heater.
   / help with heater hose connection #2
you need to go into the block with you hoses the radiator temp will not stay the same enough for a heater
   / help with heater hose connection #3
Dirtnut
the pages at the back of this pdf might help
todd k
  • Mounting Instructions John Deere 221.pdf
   / help with heater hose connection #4
If anyone is looking for a radiator hose tee, look up JTR in Google. They sell many different sizes.
Thanks for the info. I did manage to make a tee out of pipe & brass fittings they seem to be working but if they fail i will need to do something different. thanks again.
   / help with heater hose connection #6
I just purchased a 1-1/4 inline radiator hose heater for my LK. Seems to fit fine on the bench and 1-1/2 was to big. I hope I don't run into trouble with the 1-1/4 versus the 1-5/16.
Joel
what are you going to use the tees for.
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2014 FREIGHTLINER...
TABLE W/ GLASS & LEAF (A58374)
TABLE W/ GLASS &...
TEREX TH636C TELESCOPIC FORKLIFT (A52709)
TEREX TH636C...
JOHN DEERE 68 FEED CART (A52708)
JOHN DEERE 68 FEED...
2020 Ford F-150 4X4 Ext. Cab Pickup Truck (A55973)
2020 Ford F-150...
2016 Ram 5500 Chassis 4x4 ETI ETC37IH 37ft Bucket Truck (A56858)
2016 Ram 5500...
