help with heater hose connection
   / help with heater hose connection #1
Dirtnut
North Central, Pa. USA
Kioti LK3054w/cab
i have an 02 lk3054 that i built a cab for (cab project-build it yourself forum) i ordered a heater & valve kit for it but i am not sure what the best way is to tie into the radiator. i cannot find tees for the 1-5/16" radiator hoses.will i have to make my own out of pipe & weld a fitting into it.also does the bottom hose get the shut off valve to the heater.
   / help with heater hose connection #2
you need to go into the block with you hoses the radiator temp will not stay the same enough for a heater
   / help with heater hose connection #3
Dirtnut
the pages at the back of this pdf might help
todd k
  • Mounting Instructions John Deere 221.pdf
   / help with heater hose connection #4
If anyone is looking for a radiator hose tee, look up JTR in Google. They sell many different sizes.
Thanks for the info. I did manage to make a tee out of pipe & brass fittings they seem to be working but if they fail i will need to do something different. thanks again.
   / help with heater hose connection #6
I just purchased a 1-1/4 inline radiator hose heater for my LK. Seems to fit fine on the bench and 1-1/2 was to big. I hope I don't run into trouble with the 1-1/4 versus the 1-5/16.
Joel
what are you going to use the tees for.
John Deere 6125M (A50120)
John Deere 6125M...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
2013 Mercedes-Benz C-Class C250 Sedan (A50324)
2013 Mercedes-Benz...
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
