Help with grease zerks?
/ Help with grease zerks? #1
Gus3120
Hancock md
2005 john deere 3120
I bought a used 3120 and have greased all the zerks on the fel. I'm sure there are others but looking around I can't find them. Can anybody tell me where the "hidden others" are? I also hit the ones on the steering linkage. That is all that the ops manual shows. Thx Gus
/ Help with grease zerks? #2
No answers?
I don't have any specific info for 3120, but:
Is there one for front axle pivot?
Any for front wheel spindles? (On my tractor the 4wd version has none, but 2WD does)
Rear axles? (On my tractor I have to jack up tires to get weight off)
/ Help with grease zerks? #3
You can access an online operators manual on JD's website. It should tell where all the grease fittings are.
/ Help with grease zerks? #5
Can't speak for JD, but you really have to look at every pin where their is movement. Sometimes they are recessed and the opening becomes filled with dirt. I use a small screwdriver to clean out those openings so I can see the zirk fitting. On my backhoe, there are fittings that you cannot see because they are so far inside a recessed opening. I can feel them, and I can get a wrench on them to replace them, but I cannot see them. Don't forget the drive line, spindles and pedal linkage. I've tried counting how many zirks that I have on my loader backoe and always lose count before I finish. It's ridiculous!!! It also took me over a year to find all of them.
Thx for all the replys and thx to the mod who fixed the thread headline, i tried but couldnt figure how to edit that part.
/ Help with grease zerks? #7
Some zerk tips.
Tapping the ball lightly often frees it just enough to take grease.
Heating a bit with plumbers torch also restores some of them.
/ Help with grease zerks? #8
Some zerk tips.
I'll add another to the list:
Unloading the joint will sometimes allow grease to flow. The axle pivot on my equipment trailed and one steering knuckle on my truck will not take grease before I jack them up and unload those joints.
/ Help with grease zerks? #9
This is the only way to get it right. Even then, I miss some and find them months later. Got to have the owner's manual.
/ Help with grease zerks? #10
On some brands of equipment grease charts often can be found under the engine hood or inside compartment access doors.
Even my '80's CUT has the chart under the engine hood.
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
8in Channel Tooth Bucket Mini Excavator Attachment (A61572)
8in Channel Tooth...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
