Help with enclosed pole barn build.
   / Help with enclosed pole barn build. #11
Rather than start another thread, I'll glom onto this one for a while until I'm ready to start erecting something of my own.
No codes or inspections here, so I can do what I want, or what I find most cost effective that won't collapse on itself.
As a non carpenter, most of the terms used don't mean much to me. My plan is posts on 6' centers with 2xs nailed on the outside at 24OC I haven't decided on 2x4 or 2x6 yet. Headers will be either 2x6 or 2x8. I was only planning on one on the outside, but may add one inside as well. Plan was/is to use pole barn ring shank nails instead of lags. May use a nail gun to drive a few common nails first to hold things in place before driving the bigger ones. Haven't decided yet on trusses vs stick built. Pre-fab may be stronger, but they're more difficult for one person to put up and you lose potential overhead storage space.
Roof panels will be 5 rib or corrugated steel. I'm stuck on the exterior walls though. Steel 5 rib panels area finished both sides but are a bit more expensive now plus you need special screws and trim pieces. Primed wood panels like T1-11 are less costly and you can use standard screws and trim, but they are supposed to be painted. which adds cost. They're also prone to bug and rot damage.
How big a building? 2 x 6 headers are too small for a building of any decent size. I would never consider wood panels for the exterior of a pole building. Overhead storage is generally a bad idea for any building unless you actually install floor joists. Stick building a roof is OK if it is less than about 20 feet wide. Much larger and the rafters will be very large and heavy and trusses would be easier.
   / Help with enclosed pole barn build. #12
24 x 40
I have a 24 x 30 garage they stick built on site using 2x6 headers and rafters. Still standing fine nearly 20 years later. I've got quite a bit of lightweight stuff up there, small pipe, cardboard boxes, etc. that take up too much floor or closet space otherwise. I've been up on the roof several times and there is no sag anywhere.
What I've seen of trusses is that they're made from 2x4s which doesn't give me a warm fuzzy.
2012 Chrysler Town and Country (A47477)
2012 Chrysler Town...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
Zero Turn Mower (A55851)
Zero Turn Mower...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 78"...
Miller Towable Welder Generator (A55851)
Miller Towable...
