Help with CK20 noise
/ Help with CK20 noise #1
sschriber
Southern Adirondacks
Honda 5013
When my CK20 is cold and just started I've noticed a somewhat loud, intermitant noise of a medium pitch coming from the bottom of the engine when in neutral and the clutch pedal is out. Not a grinding sound. It may be part of the gear train, but it is intermittant. 2 secs on then 1 off, 3 on 1 off, etc. The tractor has a little over 40 hrs on it. Have others CK20 shift owners heard similar sound?
Also, I've notice the previously metioned "unwind sound" when the loader actually pushes the tractor back while engaged in forward gear. Is this harmful to the transmission?
/ Help with CK20 noise #2
I have a CK20 gear with about 300 hours on it. I don't notice the noise when starting cold, might be there and just haven't noticed. I do get the 'unwind sound' you refer to when working it hard and no problem yet.
ALLEN AR16 BUGGY (A63569)
ALLEN AR16 BUGGY...
12x20 Metal Carport (A64047)
12x20 Metal...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2016 Case IH Magnum 310 Tractor (A64047)
2016 Case IH...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
