SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,624
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Steve, Its easy to miss, but the anvil actually serves little function other than supporting the log while the cutter chops it. The feed drum pushes the log tip to the cutter blades and the angle on them helps drag it on in as they cut. I tried the small gap specified. Chips arent much different, but I dont think it feeds as well that way. I have mine set at about 1/8". Youre right tho, it did work OK at 1/4". Im worried that is too much overhang tho.srjones said:Ok, I can't take it anymore. Could someone explain the logic around the anvil blade gap? I keep reading two different numbers with about a 10x difference. The first gap seems to be in the shavings range (0.015"-0.035"). The second gap is in the chipping range (0.25"-0.30"). I haven't adjusted the anvils on my JM-6 and they're set at .25" and they seem to work just fine.
Is this just a preference on the finished product? Nice smooth shavings vs. course chip? Smaller shavings have more surface area...dry faster...are easier on the feet of livestock?
I can't imagine it's a performance thing, considering that a 0.025" gap would need to make 10 cuts to equal the volume of 1 cut at a 0.25"
Am I just missing something here?
Thanks in advance,
-Steve
larry
