Help with Bolt Size
/ Help with Bolt Size #1
zukota
Bronze Member
Where PA, MD, and DE Meet
DK35 H
Anybody know what the thread size is on the taped holes on the front of a DK35? The 4 bolt holes where the factory brush guard would attach. I'm going to start fabbing up a brush guard, and I don't have a big assortment of metric taps.
I can find the Kioti bolt part numbers but that doesn't really help. Already sent a PM to Rick, but was hoping someone might remember...
Thanks,
Max
/ Help with Bolt Size #2
Max what are you tapping out?
Arn't the treads already tapped in the front frame?
I am not sure of the size of the old framed DK35 but I can pull a bolt of a new one a check that for you tomorrow!
Rick,
Not tapping anything(that's plan b). On the very front of the frame is a short flat crossmember. It has 4 tapped holes where the factory brush guard, or a weight kit would mount. I believe the kioti part number for the bolt is either 01173-51425 or 01176-51240 difference being length. What I need to know is the bolt size and pitch. I'm assuming it's something like an M14, but I was trying to save some fustration..
These - just on the old frame. ...I busted the upper mounting bracket off the plastic grille. I managed to get it back together - but there is no way it will survive another blow.
/ Help with Bolt Size #5
14x1.25x35mm:thumbsup:
2020 FORD F-550 CAB AND CHASSIS (A65643)
2020 FORD F-550...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
1996 John Deere 8400 Tractor (A66285)
1996 John Deere...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
John Deere 950 Tractor (A65579)
John Deere 950...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
