Help with a John Deere snow blower
   / Help with a John Deere snow blower #11
Just another tip. If you have to replace the scrapper bar. I decided to go cheap and just use a piece of steel strapping and cut to length and drill appropriate holes. Seems to work OK. BUT when I went to recycle the old bar, I found that JD use HARDENED STEEL, so probably worth the extra expense.
   / Help with a John Deere snow blower #12
Glad you figured it out, been using one of those blowers since 2008, never a problem with belts.
Watch out for problems with the two idler pulleys. Snow sits on top of them, when you are finished the bearings are warm and the snow melts and seeps into the bearing eventually taking the bearings out to the tune of approx. $40.00 (Cdn). I made up a couple of shield a few years ago that have ended this problem just a couple of aluminum disks a bit larger than the bearing hub with the outer edge hammer formed down for about 1/16", installed on top of the idler under the retaining nut. Found this information just recently, "Pulley Shields: I ordered 2 of the deck bearing shields for my 44" snowblower idler pulleys and they fit perfectly. They cost $2.06 each with $9 shipping from Green Part Store, well worth it in my opinion. The part # M174222 is correct and was mentioned above." for a more expensive solution that probably doesn't work any better, just JDs answer to a problem. Have heard that new unit may have this installed on them.
I might assume one of two things.
1. JD never did any testing on this blower. If they had, they would have discovered the problem before offering it for sale.
2. JD knew about this problem and saw it as a "after the sale" money maker. Selling new pulleys a then later the fix.
Richard
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
DEUTZ MARATHON...
2012 MACK GU713 (A58214)
2012 MACK GU713...
