Snowblower Help with 3pt Snowblower
/ Help with 3pt Snowblower #21
How many blades on the 2nd stage fan? I had a blower with only 3 blades & wouldn't blow worth a **** at 540 RPM. My Kubota B7100 has 3 PTO speeds & when I stepped up to 780 RPM ( or whatever it is) it would blow snow into the next county. Big difference. The buddy I bought my Kubota from bought a 20hp Kioti & kept his old blower (same as mine). His tractor has only a 540 RPM PTO & is really dissappointed with his blower performance now.
There are 4 blades on the impeller. Turns real well now that my issue has been fixed (minimal clearance at the bottom too). There is only one shear pin for the auger, and it that is gone it won't turn, so I'm not sure what you are getting at there. I run it at 540 (or a little more, just beyond the orange zone on my tach)....like I said, not a lot of variables here!!!! I even sprayed the chute down with Pam, didn't do much, but made me feel like I was helping...hopefully more snow is the ticket.
/ Help with 3pt Snowblower #23
Same here and have done this for the last 3-4 years with my MT180D but run it a tad slower than WOT with no ill effects.
3 blade is definite poor design but I think impeller gap is the bigger culprit.
I guess 3 blades are less demanding HP wise like smaller diameter blower drum thereby allowing the manufacturer to claim a wider range of applications with smaller inventory.
Cost of building 4 blade vs 3 blade is actually minimal, diameter of blades would add cost however.
/ Help with 3pt Snowblower #25
Sorry I was so long getting back to you guys. Thanks for the help. Those of you saying the pto shaft was too long are the winners! Bent the frame where the gearbox is mounted, shimmed up rear bolts with a washer, and good to go.
I didn't double check pto length when I brought her home. Lesson learned. Thanks again to all.
Toby
How did you fix it, pictures would be nice please
Mahindra 4550-4L Loader (A64911)
Mahindra 4550-4L...
Caterpillar H5SE QA Hydraulic Breaker (A64911)
Caterpillar H5SE...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2022 Deere 317G (A64911)
2022 Deere 317G...
2006 Heil DOT 406 9,500 Gallon Comp T/A Fuel Tanker Trailer (A68183)
2006 Heil DOT 406...
2015 SILVERADO 5TH WHEEL (A67714)
2015 SILVERADO 5TH...
