help with 3930 pump leak
   / help with 3930 pump leak #1
turbo3930
Southern , Indiana
1998 New Holland 3930 turbo
can any one tell me what needs to be done to fix this leak on my 3930 ? It looks to be where the metal tube comes from the pump and goes into whatever.. Maybe you can tell by the pic... pump leak.jpg
Its not a BAD leak, but it needs fixed but I don't know if its o-ringed or what for sure...any help would be appreciated
   / help with 3930 pump leak #2
If you go into the NH parts website, you can see the parts breakdown and get an idea on what the problem might be.
   / help with 3930 pump leak #3
If you haven't found the solution already, the oring on the pressure tube is leaking. To remove the tube, there is a snap ring on it that must be removed, then the tube can be pushed up into the flow control valve. The oring and backup rings on the lower end can be replaced at this point. To completely remove the tube will require the hydraulic pump, lower housing, after the oil is drained from the rear axle.
I appreciate your response, I did finally find the diagram needed that showed o-ring and such but mine doesn't look exactly like the pics as far as the tube and snap rings. The pic shows a snap ring and some kind of spacer or something and mine just has a small snap ring. The leak is coming from the "control valve" side more than the pump side but I did not see an o-ring on the upper side. Do I need to replace the tube and all you think? And as far as "flow control valve", mine has no knob on it and the diagram does not show one with out knob so am I looking at it wrong or do I just have an oddity piece or what do I have??? Can't seem to find much info on what I have..
   / help with 3930 pump leak #5
Toro Mower (A50324)
Toro Mower (A50324)
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
2006 GREAT DANE 48FT FLATBED TRAILER (A53426)
2006 GREAT DANE...
2017 Nissan Titan SV Crew Cab Pickup Truck (A51692)
2017 Nissan Titan...
2021 JOHN DEERE 1725 CCS LOT NUMBER 177 (A53084)
2021 JOHN DEERE...
