Help !!! Wheel studs on l series
   / Help !!! Wheel studs on l series
Good luck getting those studs out, hope they don't twist off on you.
Looking at the condition of those studs I would not try to rethread them, there is too much meat gone.[
Thanks for the info. My brother told me the same thing and he is pretty good around that stuff. He thinks I should just send it to the dealership. They own me a favour anyways. That’s a pain because the dealer is 1 hour away and will cost me some coin on top of the dish I already bough, the studs, nuts, trip to Sydney. I’m in to about $600 or more dollars on an old wheel. Would of been better of buying a new tire and rim all assemble.
Thanks again
   / Help !!! Wheel studs on l series #12
Dealer is always an option.
I'd be tempted to try the stud remover, if they twist off then you still have 3 good options.
You can weld nuts to the broken studs and often turn them out.
Or using a left hand bit drill them out in 2-3 steps then easyout them.
Or a regular drill bit lots of heat and an easyout.
Then there is always the dealer.
Yes the dealer is an expensive option. Thanks for the info. I use to a live 30 minute tractor drive from the Kubota Dealership. I just drive the tractor there, went up the road and grabbed something to eat at the bar then drove the tractor back home. I never did like working on equipment but I found it was cheeper to drive the tractor to the deal and let them do their thing. If you work on stuff you need $5000 worth of tools, in my climate you almost need a big garage which could be $50,000, then there is my time. Now I live in a very rural area and everything you need you have to drive 2 hour round trip to get it if even if you can get it. It is almost cheeper to buy a new tractor. My tractor is 12 years old and had very little trouble so it is a great machine but now that it is 12 years old with 3800 hours of course things are going to happen. Things like Hoses, time to adjust the values, maybe a rad in a few years, tires are wore, new tires on front about 2 years old but like all Carile tires they are cracked, etc.... The last two months I put $1500 into it. I envy the guys that has a place, the patients and the skills to work on stuff themselves. I know there are lots of you out there because in my machanical stupidity I post stuff and many of you have the fix and skills to do it. Thanks you all for your help. You have all been great. At least now I know my options.
2007 International 4200 Homemade S/A Chipper Truck (A56858)
2007 International...
1449 (A57192)
1449 (A57192)
16001 (A55853)
16001 (A55853)
2022 Morbark Eeger Beever 1215 Towable Brush Chipper (A56857)
2022 Morbark Eeger...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
Clark C500-40 Warehouse Forklift (A57148)
Clark C500-40...
