Help, what size do I need ?
   / Help, what size do I need ? #1
goochy
Newbee here , Been looking at L35s and L48s Backhoe /Ftend loader . Or looking for a ft end loader 4x4 tractor . I do not need a L35 or L48 , I just thought it would be nice to have a backhoe . I have a old 3000 Ford diesel tractor ( 42 hp) now 2x4 NO loader . I work on 2 , different 3 acea lots . I have a 6 ft box blade , 6 ft bushog , and a 6 ft grooming mower . I blade around 5-7 driveways in rual area for friends . Box blade alot , doing dirt work . I only use tractor a few times a year . Would LOVE to buy new , but having a hard time paying so much for new tractor . I have $10,000 to spend plus what ever the 3000 sells for . SO I might have $11,000-$14,000 to spend . No More . On a budget , so looking for a clean used tractor 4x4 with loader , or do I buy new with 0 down and 0 % for 5 yrears ???? What size should I look for to do work above with 6 ft equipment ? Thanks .
Looking at a L4610 with loader this weekend
needs TLC ( seat, light , tailights, and paint is fair) $13,500 as is , or MORE is he cleans it up and fixes it .
Looked at 2 L35s both junk for $14,000
Missed a CLEAN L48 low hrs , sweet rig for $17,000 it sold , I offered $15,000 and it sold 2 hrs later for $17,000
   / Help, what size do I need ? #2
I have a L4200, Love it and really would not want a smaller one.
You are on the right track looking at L4xxx size... and a good used tractor is got to be the best way to go..
I hate the thought of buying new, as soon as you use it it becomes 'good used equipment' ... so you just as well start out looking for 'good used equipment' and put the difference in new/used price into more attachments... KennyV
   / Help, what size do I need ? #3
There are a couple of guys on here who have the 4610, I think Piston just got one and they really like them. I have bought used but you probably will have to go more than five years old to get a significant discount. I bought one seven years old and saved quite a bit. It was well taken care of with the maintenance record.
We own and old backhoe and no longer even use it. For us it is cheaper to rent one or an excavator instead of buying one and keeping up with it. We can do pretty much all e need to with a FEL.
I personally like a 40-50 HP for all around utility work unless size is a problem then there are a lot of smaller tractors from which to choose.
Good luck.
The 4610 looks ok , dirty , but needs TLC . Its got 1700 hrs . I just do not want to buy to small . I think the 40 + hp is the way to go . Thanks for any info.
   / Help, what size do I need ? #5
I went shopping for a 30-40 HP and wound up with a 50HP and I am sure glad I did.
1700 hours isn't much on a tractor, so it may very well be a good deal. We have a couple of tractors that look pretty rough due to their age and exposure to the elements before we bought them, but they are really dependable
The 4610 is sounding better , its a 2002 L4610 with factory loader , rear hydrulics( center arm and 1 down arm) 1756 hrs , looks ok in pics , he said it runs strong .
NEEDS !! TLC !!
Seat - torn
Light - broken
Tailights - Broken
oil leak - around oil pressure sending oil ?
Tilt wheel - stuck ( he said he has seen this before , needs taken apart )
Tie rod ends- some play
Draw Bar - all missing
Floor Matt - missing
He said for $500-$1000.00 plus ALOT of cleaning I could have a nice tractor .
$13,000 FIRM :(
Tires - good cond
Paint - needs wax
FEL - good cond, tight
Canopy - good cond
   / Help, what size do I need ? #7
NEEDS !! TLC !!
Seat - torn
Light - broken
Tailights - Broken
$13,000 FIRM :(
Tires - good cond
Paint - needs wax
Canopy - good cond
It sounds like a pretty good deal, but with only 1700+ hours, I am surprised the tie rod ends are loose. You might want to check to see if they are worn out or just not properly torqued. They are not hard to replace and all of the other stuff seems fairly simple to remedy.
May be some good info here: http://www.tractorbynet.com/forums/kubota-buying-pricing/192488-l4610-should-i-pull-trigger.html
This guy is trying to tell the truth about the tractor , anything he would fix before he sells it , but I am getting the as is price. He said for $600.00 he could fix everything , not counting man hrs to tighten stuff, clean and wax. He said it should be a $16,500- $17,500 tractor fixed up . As long as it runs good , everything works I do not mind to fix a few things to save some cash .
   / Help, what size do I need ? #9
Not only will you save some money, you will get to know your tractor better.
I honestly don't know about the price though, maybe someone can give a better idea; seems good to me, but I may be way off.
This may give you a little insight into tractor prices:http://barlowequipment.com/used.htm
   / Help, what size do I need ? #10
Reality moment here! You have a total of 6 acres you are caring for. You have said in every post you have started that you only use the tractor a 'few times a year'. Why would you buy that big of tractor for that much money given your use? Starting to sound fishy.:confused3:
MarkV
2013 Dodge Durango (A53317)
2013 Dodge Durango...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
12' CONTAINER (A52706)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
296385 (A57192)
296385 (A57192)
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
