Loader Help!! trying to install a 270tl loader
   / Help!! trying to install a 270tl loader #1
starcruiser
I'm trying to install a 270tl loader on a caseih dx55. I would greatly appreciate pictures of the hydraulic connections. Both at the diverter valve and the loader controls. THANK YOU VERY MUCH in advance. This site provides a wealth of information
   / Help!! trying to install a 270tl loader #2
i have not a clue about your tractor, so best i can do is below for ya.
http://partstore.caseih.com/us
click "find by model number" enter your model click search, and select type of tractor you have (based on S/N (serial number) and or if you have a cab or not.
it may give listings of FEL (front end loader), along with various hoses and pipes and fittings. ((possibility of needing to route around stuff and a metal pipe / fittings might work better vs a rubber hose))
a "shop / service manual" would then be your next best bet, for getting pictures/diagrams and how things go together.
Thank you for the reply Ryan . A dx55 (case/ih) is the same as a tc55da-except its red . I was hoping for some pics , to verify routing . thanks again
   / Help!! trying to install a 270tl loader #4
Any NH or CiH dealer can supply published installation instructions for the 270TL or its red equivalent.
   / Help!! trying to install a 270tl loader #5
I'll try to get some pictures for you. But as Rick said, you'll be better off with the installation instructions from your dealer.
Also, here's a link going directly to the 270TL parts diagram in case that helps. Select (006) for the control valve and tubes. 270TL
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2005 INTERNATIONAL 9400I MID-ROOF SLEEPER (A58214)
2005 INTERNATIONAL...
PALLET OF MISC HOSE & PIPE INSULATION (A58374)
PALLET OF MISC...
2016 Cadillac CTS (A56859)
2016 Cadillac CTS...
POLY TOTE W/ METAL CAGE & PALLET (A52708)
POLY TOTE W/ METAL...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
