Loader Help!! trying to install a 270tl loader
   / Help!! trying to install a 270tl loader #1
starcruiser
I'm trying to install a 270tl loader on a caseih dx55. I would greatly appreciate pictures of the hydraulic connections. Both at the diverter valve and the loader controls. THANK YOU VERY MUCH in advance. This site provides a wealth of information
   / Help!! trying to install a 270tl loader #2
i have not a clue about your tractor, so best i can do is below for ya.
http://partstore.caseih.com/us
click "find by model number" enter your model click search, and select type of tractor you have (based on S/N (serial number) and or if you have a cab or not.
it may give listings of FEL (front end loader), along with various hoses and pipes and fittings. ((possibility of needing to route around stuff and a metal pipe / fittings might work better vs a rubber hose))
a "shop / service manual" would then be your next best bet, for getting pictures/diagrams and how things go together.
Thank you for the reply Ryan . A dx55 (case/ih) is the same as a tc55da-except its red . I was hoping for some pics , to verify routing . thanks again
   / Help!! trying to install a 270tl loader #4
Any NH or CiH dealer can supply published installation instructions for the 270TL or its red equivalent.
   / Help!! trying to install a 270tl loader #5
I'll try to get some pictures for you. But as Rick said, you'll be better off with the installation instructions from your dealer.
Also, here's a link going directly to the 270TL parts diagram in case that helps. Select (006) for the control valve and tubes. 270TL
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58018)
2018 FREIGHTLINER...
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
2014 Bolens 11A-020W765 20in Push Mower (A55973)
2014 Bolens...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2017 MACK  CXU613T (A58214)
2017 MACK CXU613T...
Toro San Pro Bunker Rake (A56857)
Toro San Pro...
