help..transmission/hydriolic oil
   / help..transmission/hydriolic oil #1
fish_wisperer
Banned
east of dallas
mahindra 4500 2wd
i use chevron machine oil aw or something like that in my 4500 2wd, does anyone know if its close to being compatible with john deere 303, i have a yanmar i want to put it in.. the dip stick is stuck so i just want to drain it and put the right amount in and i have 5 gallons of the chevron on hand,the chevron machine oil is not a low viscosity hydrolic fluid.
   / help..transmission/hydriolic oil #2
Hi fish,
Does your oil have any kind of codes on it (JDM J20C/J20D)?
Those are the grades/equivalents the 3X20's will take.
   / help..transmission/hydriolic oil #3
Check with your John Deere dealer and see if the JDM 303 has been replaced by the JDM J20C or JDM J20D. Here's a product data sheet from Petro-Canada that indicates the JDM 303 is an older spec that has been replaced by JDM J20C or J20D, but it's not clear to me if it's both or only one of them.
  • PetcanDuratran.pdf
thanks, ill look at the bucket again.
   / help..transmission/hydriolic oil #5
Not the brand you were asking for but I had this info handy, maybe there is some info here you can use?
Synthetic Tractor Hydraulic/Transmission Oil
SAE 5W-30 (ATH)
Formulated for "All Weather" Performance in Farm and Commercial Equipment.
PERFORMANCE DATA
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is recommended for applications that require any of the listed specifications:
* AGCO/Duetz-Allis/Allis-Chalmers
Power Fluid 821 XL, 257541, 246634
* Allison - C-4, C-3, C-2
* Case Corp. J.I. Case & IH
MS-1207 (Hy-Tran® Plus), MS-1210 (TCH Fluid JIC145), MS-1230 (Poclain Equip-high pressure systems), B-6, MS-1206 (PTF), MS-1205 (TFD-II), MS-1204 (TFD), JIC-185, JIC-144, JIC-143, B-5
* Blearus
* Caterpillar - TO-2
* Clark - TA 12, TA 18, HR 500, HR 600
* Dresser CED - Trans/Hyd Fluid
* Hesston Fiat - Oilofiat Tutela Multi-F, AF-87
* John Deere - J20C, J20D (Winter grade), J20A/B, J14B, JD 303, J21A
* Kubota - UDT
* Landini - Tractor II Hyd. Fluid
* Leyland
* Massey-Ferguson - M-1141 (Permatran® III), M-1135, M1143, M1129-A, M-1127-A/B, M-1110
* New Idea Power Units
* New Holland Ford - M2C134-A/B/C/D, FNHA-2-C-201.00, FNHA-2-C-200.00 (Winter grade), M2C86-B, M2C53-A, M2C41-B, M2C48-C
* Oliver - Q-1802 Type 55
* Steiger - Hyd/Trans SEMS 17001
* Sundstrand - Hydrostatic Transmission Fluid
* Valmet
* Versatile - M2C134-D FNHA-2-C-201.00, Spec 24M, Spec 23M
* White Farm (Oliver) - Q-1826, Q-1802, Q-1766B, Q-1722, Q-1705
* Yanmar
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is recommended for the replacement of, but not limited to, the following oils:
ARCO Tractor Fluid; BP Tractran UTH; Case Hytran; Chevron Torque Fluid; Chevron Tractor Hydraulic Fluid; Conoco Power-Tran III Fluid; Conoco Farm Master; Gulf Universal Tractor Fluid; John Deere Hy-Gard; Kendall HYKEN 052; Kubota UDT; Lubrication Engineers 7500; Lubriplate UTF C-4; New Holland, Ford M2C134-D & FNHA-2-C-200.00 & 201; Mobilfluid 300, 350 and 424; Pennzoil HYDRA-TRANS; Phillips HG Fluid; Royal Purple SYN-TRACTOR III WG; Shell Donax TD
The Chevron products above seem to be what you should use but I am no expert on that. Thats why I have this info as a friend has a skid steer with a Yanmar diesel engine that he wants to changeover.
   / help..transmission/hydriolic oil #6
Can anyone tell me who makes traveller for TSC ? I have heard that it is made by its name but can't find it online. May be useing the wrong search wording.
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
2009 VOLVO VNM DAY CAB (A54607)
2009 VOLVO VNM DAY...
2016 CLUB CAR (A53424)
2007 International 4400 2,000 Gallon Water Truck (A52377)
2007 International...
John Deere 2640 2WD Tractor with 146 Front Loader (A55218)
John Deere 2640...
