Help to adjust a cluch kubota b7610
   / Help to adjust a cluch kubota b7610 #1
Corty
Farmington,ct.
Kubota b7610
My cluch will not do anything, machine keeps going in gear when you push in cluch.....pto keeps spinning....yet I can change it from low to high no problem. Any suggestions on how to adjust
   / Help to adjust a cluch kubota b7610 #2
Has this problem graduly gotten worse to this point or work fine then be parked for an extended period of time then not work?
If the clutch is worn, replacement may be needed...if it's stuck (disks froze to flywheel/pressue plate) then it is a whole new ball game.
Lets hope your tractor doesn't need to look like this L2850 I'm working on now...
   / Help to adjust a cluch kubota b7610 #3
What trans do you have in it?
Wow that looks like a quiet the project. I just bought this machine clutch just does not disengage i think it just needs adjusting which I seen how to adjust in the owners manual so I will give that a try this weekend
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51242)
2022 CATERPILLAR...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
2006 International 4400 LP Crew Cab S/A Heavy Haul Truck Tractor (A49461)
2006 International...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
S/A Utility Trailer (A49461)
S/A Utility...
2011 NEW HOLLAND W130B WHEEL LOADER (A50854)
2011 NEW HOLLAND...
