Help to adjust a cluch kubota b7610
   / Help to adjust a cluch kubota b7610 #1
Corty
Farmington,ct.
Kubota b7610
My cluch will not do anything, machine keeps going in gear when you push in cluch.....pto keeps spinning....yet I can change it from low to high no problem. Any suggestions on how to adjust
   / Help to adjust a cluch kubota b7610 #2
Has this problem graduly gotten worse to this point or work fine then be parked for an extended period of time then not work?
If the clutch is worn, replacement may be needed...if it's stuck (disks froze to flywheel/pressue plate) then it is a whole new ball game.
Lets hope your tractor doesn't need to look like this L2850 I'm working on now...
   / Help to adjust a cluch kubota b7610 #3
What trans do you have in it?
Wow that looks like a quiet the project. I just bought this machine clutch just does not disengage i think it just needs adjusting which I seen how to adjust in the owners manual so I will give that a try this weekend
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
Unused 2025 CFG QK16R Mini Excavator (A49461)
Unused 2025 CFG...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
1041 (A50459)
1041 (A50459)
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
