Help. The hydraulics quit working
   / Help. The hydraulics quit working #1
saxon
Pelzer, S.C.
Kubota B1550, L3800
On the BX2230 HST, the hydraulics for the rear totally quit working and the FEL hydraulics work but not normally??
The transmission is full of fluid.
I worked it hard the last time I run it 2 days ago, but not that hard??
What all can I check?
   / Help. The hydraulics quit working #2
I'm not familiar with that model, when you say the "rear totally quit working", do you mean there is a remote rear hydraulic valve that isn't functioning? Or do you mean the 3pt isn't working? Describe what you mean by the FEL is not functioning normally. Does the transmission work properly, so it goes forward and backward normally?
The HST trans works fine in forward and reverse.
I do mean the 3 pt hydraulics are not working, at all.
The FEL will work but just barely creeps up, and to go down the lever has to be pushed all the way forward till it moves past a detent.
The bucket roll works right though.
Hallalooyah
There was a QD fittin up near the lever that snapped in placed when I pushed on it.
Now everything works fine.
thanks Tunga
2012 Ford Expedition XLT 4x4 SUV (A50324)
2012 Ford...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
2017 Isuzu NPR Crew Cab 14FT Landscape Dump Truck (A50323)
2017 Isuzu NPR...
2013 Lexus ES Sedan (A50324)
2013 Lexus ES...
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
