Help. The hydraulics quit working
/ Help. The hydraulics quit working #1
saxon
Member
Pelzer, S.C.
Kubota B1550, L3800
On the BX2230 HST, the hydraulics for the rear totally quit working and the FEL hydraulics work but not normally??
The transmission is full of fluid.
I worked it hard the last time I run it 2 days ago, but not that hard??
What all can I check?
Thanks
/ Help. The hydraulics quit working #2
I'm not familiar with that model, when you say the "rear totally quit working", do you mean there is a remote rear hydraulic valve that isn't functioning? Or do you mean the 3pt isn't working? Describe what you mean by the FEL is not functioning normally. Does the transmission work properly, so it goes forward and backward normally?
The HST trans works fine in forward and reverse.
I do mean the 3 pt hydraulics are not working, at all.
The FEL will work but just barely creeps up, and to go down the lever has to be pushed all the way forward till it moves past a detent.
The bucket roll works right though.
Hallalooyah
There was a QD fittin up near the lever that snapped in placed when I pushed on it.
Now everything works fine.
thanks Tunga
2005 John Deere 7420 (A60462)
2005 John Deere...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
1979 Ford 5000 (A64126)
1979 Ford 5000...
378908 (A61166)
378908 (A61166)
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2022 EZ-GO ELITE...
