help running out of hair to pull out
   / help running out of hair to pull out #1
mike b2
4520 john deere ol 6'
Hi EVERYBody, I have an ol 4520 jd that's about to make me pull all my hair out worrying with it.. what it is doing is when u first crank it up it smokes badly . Its a white diesel smelling type smoke and it mis a lil. So I thought ,Ok no problem probly injecter bad replaced all 6. Ok tried it again same thing no change. Ok no problem pump had it rebuilt by highly referd company. Put pump back on same thing . But what does is when I pull a disk with it for a while it clears up and quit missing, runs good. But when I cut the tractor off a few mins it does the same thing again. It not using oil , not adding water , not running hot,it does have a lil blow by out the vent tube but not a bug killer. The ol gal is strong pulls good I tried talkn to jd tects and tried there advice but nthn works.. any info would be greatly helpful. Thanks
   / help running out of hair to pull out #2
Welcome to TBN. :)
Thanks ill try tht:thumbsup:
I've been lookn in the parts and repair section and no luck ... :(
2024 Kearney 7'x20' Trailer (A50123)
2024 Kearney...
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
Towable Sprayer (A51691)
Towable Sprayer...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
