help replacing seal
/ help replacing seal #1
geneo
the front axle case seal on my kubota L2550 is leaking and i would like to replace it as soon as i can but would like some input on how is the best way to tackle it , also does anyone know the seal # ?? thanks in advance
/ help replacing seal #2
Is this a 4wd? 2WD?. With most wheel systems you basically just start taking stuff off from the outside and work in. Lay the parts on the ground in order (or download a parts manual). 4WD will be a little harder because of the steering knuckle and parts around it.
Good Luck,
Rob
/ help replacing seal #3
Many bearing shops can order a seal if they can read the numbers off the old one or if you give them the ID and OD for the seal you need.
A seal puller works much better than a screwdriver to remove seals- I bought one recently and wondered how I had gotten by so amny years without one (they are less than $15 at an auto parts store).
/ help replacing seal #4
When you get in to the seal, try to remove it without damaging the sealing lip.
Then you can check whether it was worn or damaged, check also for wear from the lip on the shaft, if the shaft is worn see whether you can get the seal in or out a bit next time or fit a speedie sleeve.
Check also for slack in the bearing or bush before reassembling.
Allenr
2011 Kubota KX080-3 (A64911)
2011 Kubota...
80 Gal Fuel Tank (A64912)
80 Gal Fuel Tank...
John Deere 4045 4 Cylinder Power Unit w/PTO (A64911)
John Deere 4045 4...
2023 Dodge Challenger Coupe (A66738)
2023 Dodge...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
(6) 5-Spoke Dayton Hubs (A64912)
(6) 5-Spoke Dayton...
