HELP! Repair or Replace
/ HELP! Repair or Replace #1
keegs
The County, ME
Kubota M5640SUD
IMG_20190417_115930509.jpgIMG_20190417_115938337.jpgIMG_20190417_115948284.jpgIMG_20190417_115959326.jpg
If I can find a replacement U joint is this worth repairing? ...Have no idea how to assess this. The bearing seat on the quick connect looks pretty worn but may it still be usable as is? It's off my Pronovost snow blower.
Thanks...
/ HELP! Repair or Replace #2
I don't see anything repairable there.
Thanks ... I'm taking a ride to TS now to see if they have a replacement shaft/joint and connector... any recommendation where to source the part?
/ HELP! Repair or Replace #5
If you have an automotive driveline shop near by they generally have the parts and can assemble and weld the shaft on. Many far supply stores have them, Agri Supply has them on the web as do other suppliers.
Thanks Jerry... This has the triangle shaft and TS didn't carry that type. I hit a local tractor shop. They can make one up for me or they can order one from their supplier ...that I'll have to cut to fit myself apparently. I'm going to shop around online to see what's available. I'm thinking, no rush....the snow is melting pretty fast here ...maybe another week and I'll be good until next winter.
/ HELP! Repair or Replace #7
We have a local machine shop that builds / rebuilds drive shafts.. used them a few times to balance a drive shaft and a couple times to just swap out U joints. Really nice quality and fair priced.
Thanks Tom... I've been muddling through online and found the specs on the Pronovost P-680 blower (my attachment). Looks like it has a T40 PTO shaft. I may make a few phone calls tomorrow to try to pick up some more info. The male end of the shaft coming off the snowblower looks fine, So I need the T40 female triangle shaft, the yoke, the U joint, the other yoke and the PTO connector piece. Getting those as a package is what I'm shooting for. The guys at Crown in Caribou were a big help to me today... I may just give them the work. I think they're wanting $250.
/ HELP! Repair or Replace #9
I'm no expert but it looks to me you can just swap out the U-joint and run it. Is the piece inside the right hand piece with the damage the shaft that slips? If so, It looks like your shaft is too long and pushed into the u-joint? I've seen way worse on Jeeps and with some finesse they were usable and they see a lot faster speeds than your blower will. Pound those ears back into shape, make sure your shaft isn't too long and put in a new U-joint and run it, u-joints are cheap. Another trick is to put some tack welds on the caps to keep them in place if need be. When the U-joint explodes on a Jeep while the front is spinning it can and has taken out the lower ball joint (no fun on the trail) so we've adapted ways to help keep this to a minimum.
/ HELP! Repair or Replace #10
I just had to buy one for my auger. I found the best price at Agri Supply online.
The shaft is pinned through the yoke keeping it from slipping. That pin snapped and the shaft was able to slip through damaging the U joint.
I bought the blower used and have been running it for 4 or 5 years now without any problem. The specs identify the shaft as a size T40 and that identifier is stamped on the shaft cover. However it could be that it was purchased separately (the blower is sold without the shaft) and not cut to proper length. So it well could be that it's too long (on the margin perhaps??...)
There's two guys in town that do equipment repair work like this. Either might be interested in looking at it. If the shaft is salvageable and a new pin could be fabricated and installed I'm pretty sure I can pick up a replacement U joint at TS. I'm not sure about tacking the U joint to the yoke but he may be able to restore material around that worn seat with the welder, a drill and a grinder?? Can't hurt to ask.
I found what I think is a replacement PTO shaft (the whole shootin match) w/end connectors, shear pin etc...on Agri-Supply w/ shipping for $165. That might work too.
A little concerned if I have to return it. I called to confirm my selection but it didn't go as well as I wished it could have.
/ HELP! Repair or Replace #13
I bought my shaft for my logging winch from agco, I had to cut it down but other than that it works great.
Good luck!
/ HELP! Repair or Replace #14
Hopefully you're done using that for the season.
/ HELP! Repair or Replace #16
That shaft could be cobbled back together and might work for several seasons and could blow out the first time used.
For that inner shaft to push back hard enough to break the pin and get shoved back into the u-joint the shaft was either too long or it had seized.
There are several places online that all the individual components can be purchased from and assembled into a complete good shaft.
But I would expect it to be cheaper to purchase a complete new shaft and cut it to the proper length and have several years of service from it.
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
155 (A64278)
155 (A64278)
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
