Help rebuilding cylinder
   / Help rebuilding cylinder
Thanks for all the tips! I ended up having to buy a 1 1/2" impact socket. Clamped the rod in my vise with cardboard and a rag protecting the cylinder, and the impact wrench took the nut right off (keep in mind I couldn't budge it with a large adjustable wrench and pipe extension!). Replacing the seals was pretty straightforward... got it all back together and it is working like a champ... no leaks!
   / Help rebuilding cylinder #12
I'm glad you got your cylinder repaired and it is working well again for you now. You called and spoke to me on Jan. 10th. If I neglected to, I apologize for not telling you that you would likely need an impact wrench to remove the piston nut. We torque the piston nut to 275 - 330 Ft.Lbs.
I was purusing various threads on TBN and stumbled on yours so I had to look and see if you had spoke with me. I learned something from you here, that is I should also tell the customer what size impact socket will be required.
Best Regards,
Steve Hansen
Applications Engineer
Energy Manufacturing Co., Inc.
(319)-465-3537 X-402
(319)-465-5279 FAX
shansen@energymfg.com
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
Cruise Car Electric Golf Cart (A50860)
Cruise Car...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
2007 John Deere 7930 4WD Tractor (A50860)
2007 John Deere...
