Help! - put UDT in engine
/ Help! - put UDT in engine #1
mrgries
Mt. Airy, MD
Kubota BX-23
Was doing the 300 hour service and had my head up my ... er ... wasn't paying attention and dumped UDT into the crankcase. I caught myself before starting the tractor and am letting it drain out. What should I do? Will the engine get screwed up from the UDT?
Thanks in advance.
/ Help! - put UDT in engine #3
i would drain it, fill it with oil run it an hour or so and change it again. i would also change it 5 hours after that. not much else you can do.
/ Help! - put UDT in engine #4
Thanks in advance.
Since you didn't start it, there won't be in much of it in the engine to where it won't come out just draining. Just let it drain out and put the right oil in. It won't cause any problem what so ever. After it is drained don't think anything else about it.
/ Help! - put UDT in engine #6
Drain UDT, put oil in. Change after you run it, change oil, run it and change oil. Simple dilution. Think of how nice and clean you engine will be :D !
Bob
/ Help! - put UDT in engine #7
Bob
I think that may be a little excessive. It was not run so it's only in the crankcase. And it's not like it's acid or anything. It's a lubricant itself. I would drain it and if you are really worried about it fill the crank case with diesel to normal oil levels and drain that. Might be a little cheaper than the oil.
/ Help! - put UDT in engine #8
Doesn't AMSOil make some sort of a cleaner you put in the crankcase and run it for 30 mins or so and drain that? That would my preferred course of action. Course finding an AMSOil dealer isn't always the simplest of tasks.
/ Help! - put UDT in engine #9
Yes, excessive. What can I say :D ?
Bob
/ Help! - put UDT in engine #10
Thanks in advance.
Is it ok to start making fun of you now, or do we need to give you a grace period?
/ Help! - put UDT in engine #11
NO~~!
Don't make fun of him, he actually was doing his own service.
jb
/ Help! - put UDT in engine #12
Ah heck!!! Let's make fun of him now. There's no sense in missing an opportunity.
Have at it - won't be the first time. :) In my defense, I'll point out that Kubota Oil and UDT are sold in very similar looking containers.
/ Help! - put UDT in engine #14
I gotta say give him a walk...
Sure it was a silly thing to do, but took real GUTS to admit it here.
Salute! :D
RDnT
/ Help! - put UDT in engine #15
Hmmm... first time is OK. Everyone has the right to make a mistake... as long as it's not with my tractor, my car or my truck ;) . If you want a good advice: please if you do the same mistake again don't tell anyone.
My ex-wife put windshield fluid in the coolant recovery tank of one my former cars 3 times :eek: . One time is OK, I'm sure you learned from your mistake.
Well, since several people seemed to think letting the UDT drain was sufficient, verifying that there wasn't any UDT in the new oil filter, and because it was the easiest of the suggested options :) I filled up with the correct oil and after 10 hours or so worth of mowing (i.e., most of one tank of fuel - seems to be a bit more fuel efficient after getting fresh oil) the engine seems to be happy and none the worse for the experience.
I am, however, noticing an occasional vibration of some sort from the HST, typically after the tractor has been running for a while. Stopping forward motion, then starting out again seems to make it disappear for a while (no, I did NOT put engine oil in the HST! :)) - hoping this is nothing serious.
Thanks again for all your advice.
/ Help! - put UDT in engine #17
If you have ag tires then it could be the tires getting into a harmonic vibration thing. It happens to mine on paved roads.
/ Help! - put UDT in engine #18
Thanks in advance.
If you put in SUDT you would have been fine..
LBrown59 said:
I was wondering how to tell the engine from the tranny but I haint gonna ask him.
ROTFLMAO!
Tough crowd. Actually, I think I got that one figured out, but surely you guys can give me some suggestions to make sure?
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2019 Chevrolet Express 2500 Cargo Van (A61573)
2019 Chevrolet...
LOOK! (A63109)
LOOK! (A63109)
ATTENTION! PLEASE READ (A64119)
ATTENTION! PLEASE...
2012 Gastron 18ft Boat w 18ft S/A Boat Trailer. (A61574)
2012 Gastron 18ft...
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
