HELP... PTO ISSUES
   / HELP... PTO ISSUES #1
F350
USA
Red
I tried to repalce the PTO seal on my YM226 and when I pulled the PTO cover off a transmission assembly came out with it!!! I put it back together and now the PTO won't disengage. It stops turning with the clutch engaged.
Under load as the PTO shaft slows down you can hear a clicking noise coming from the PTO shaft.
How do I fix my tractor?? Any ideas??
My PTO was working fine before I tried to replace the PTO seal. I must have done something wrong @ reinstallation.
Are there any reinstalltion tips when installing the PTO gear cluster?
PTO lever position?
Any ideas would be appreciated.
   / HELP... PTO ISSUES #3
Disconnect all the shifting linkage before reassembly. You have to " feel ' the linkage levers go back into the shift slots as you push the assembly back in.
   / HELP... PTO ISSUES #4
The YM226 service manual shows & tells how to do it.
Danny
Thanks for the suggestions. I did notice that you have to "feel" the PTO gear cluster engage the internal shaft as you install it. I was unaware of the need to disconnect any linkages.
I guess I need to invest in a YM226 service manual.
Thanks,
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A53426)
2013 PETERBILT 386...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A51691)
2015 John Deere...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2013 Chevrolet Silverado 1500 Pickup Truck (A53117)
2013 Chevrolet...
2012 Ford Explorer (A50123)
2012 Ford Explorer...
