Help! Power Steering Leak
/ Help! Power Steering Leak #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
Mahindra 5500 4WD is leaking fluid from top of steering column under steering wheel. takes a little time to start and will drip steady. I have not removed Steering wheel yet.
Any ideas of what to look for to repair??
/ Help! Power Steering Leak #2
Fluid has to be leaking past a seal on the bottom of the inter column. Need a further break down. May be a common problem that the dealership has dealt with on similar tractors. That is where I would start at.
/ Help! Power Steering Leak #3
Looks like the steering box at the bottom of the steering shaft has a bad seal.
It's pumping the fluid up the shaft.
2013 FORD E-SERIES VAN (INOPERABLE) (A67714)
2013 FORD E-SERIES...
CASE 721E WHEEL LOADER (A67714)
CASE 721E WHEEL...
2013 Ford Fusion Sedan (A66738)
2013 Ford Fusion...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
