Help! Power Steering Leak
/ Help! Power Steering Leak #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
Mahindra 5500 4WD is leaking fluid from top of steering column under steering wheel. takes a little time to start and will drip steady. I have not removed Steering wheel yet.
Any ideas of what to look for to repair??
/ Help! Power Steering Leak #2
Fluid has to be leaking past a seal on the bottom of the inter column. Need a further break down. May be a common problem that the dealership has dealt with on similar tractors. That is where I would start at.
/ Help! Power Steering Leak #3
Looks like the steering box at the bottom of the steering shaft has a bad seal.
It's pumping the fluid up the shaft.
FUEL TANK (A68842)
FUEL TANK (A68842)
2015 FORD TAURUS CAR (A66091)
2015 FORD TAURUS...
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
2012 ATLAS COPCO  AIR COMPRESSOR XAS 375 (INOPERABLE) (A68842)
2012 ATLAS COPCO...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2018 Ram 1500 4x4...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
