cvcman
ok I notice the short hose on the right side of the loader is leaking at the fitting..it seems to leak when you have the bucket tipped all the way in the dump position..there is a 90 coming off the ram, the jam nut there was leaking a little so I tightened it,,that seems ok but where the fitting screws on to the 90 its leaking around the threads under pressure..
I tightened it too and it seems better...so couple questions:
1) is the 90 tapered and that's what seals inside the female end of the hose ?
2) I was thinking of taking it off and cleaning up the threads and using thread sealant ???
3) So would the hose and or 90 need to be replaced ?? Or is there a washer inside the hose fitting ??
4) would this be a warranty item ?? Its only 3 yrs old and 60 hrs
