Help pls ! LSXJ2025H hydralic fitting leaking
/ Help pls ! LSXJ2025H hydralic fitting leaking #1
cvcman
syracuse ny
john deere
ok I notice the short hose on the right side of the loader is leaking at the fitting..it seems to leak when you have the bucket tipped all the way in the dump position..there is a 90 coming off the ram, the jam nut there was leaking a little so I tightened it,,that seems ok but where the fitting screws on to the 90 its leaking around the threads under pressure..
I tightened it too and it seems better...so couple questions:
1) is the 90 tapered and that's what seals inside the female end of the hose ?
2) I was thinking of taking it off and cleaning up the threads and using thread sealant ???
3) So would the hose and or 90 need to be replaced ?? Or is there a washer inside the hose fitting ??
4) would this be a warranty item ?? Its only 3 yrs old and 60 hrs
/ Help pls ! LSXJ2025H hydralic fitting leaking #2
I would call your dealer to see if it is under warranty. Tell him everything you did.
Without seeing the part, it is hard to tell what fitting your speaking of. Some fittings are tapered and some need pipe dope. Never use the tape stuff though.
Ok NOT warranty item, only one yr on these...Its a JIC fitting coming off the ram, these have a tapered end that seat into the female fitting on the hose..so it could be the fitting OR the hose...Im wondering IF I can just clean it up with brake cleaner and use some blue pipe thread dope...cant hurt right ?
/ Help pls ! LSXJ2025H hydralic fitting leaking #4
I'd think as long as you kept it out of the oil it wouldn't hurt. Could you clean the thing up and recheck if it is hose first?
Already did that,, it痴 not the hose, coming out around the threads where the hose fitting screws onto the 90 coming out of the ram ... I知 not sure if this fitting is part of the hose it almost looks like the hose is threaded onto the female fitting
C8A29A43-8B2C-480B-A7AE-735A1F02CCBF.jpeg38D7BC24-BA24-48E5-AB28-CB1014FB20AA.jpeg1AD0620C-A111-45CA-9595-05224859A405.jpeg
/ Help pls ! LSXJ2025H hydralic fitting leaking #8
The female fitting looks to be the swivel fitting on the end of the hose. When you look at parts, they just show (starting at the cylinder) an o-ring, elbow and hose. When you look at the tractor it does look different.Did they use an adapter at the cylinder? Me? I would lower the bucket, move the lever around to release pressure put in to float and pop it apart and have a look.
but what am I looking at or for ?? If its the swivel fitting why is there another nut behind the female fitting ?
/ Help pls ! LSXJ2025H hydralic fitting leaking #10
The nut just may be cast on the barb of the fitting to hold while loosening the female. Doesn't hurt to try.
/ Help pls ! LSXJ2025H hydralic fitting leaking #11
This.
Take it apart and see how it works. You can always put it back together. If you learn that the fitting on the hose is the culprit, take to hose off, take it into your tractor dealer or someone who makes hoses in your area, and get the hose replaced. If it's simply the fitting, go get another fitting.
Dont be afarid to take things apart to see how they work. Thats how we learn.
/ Help pls ! LSXJ2025H hydralic fitting leaking #12
Ok the first pic on the left and the middle pic shows the hose where it threads onto the 90...its leaking right around the threads of the female fitting, again it looks like this fitting is threaded onto the hose, not the nut behind the fitting...
So is the 90 bad or the fitting ?
And does this fitting unthread off the hose ??
Total WAG (not even a SWAG) but it looks to me, I can't tell if it's an NPT or not...... I don't think it is. There might be a nylon 'washer' the male fitting seats against inside the female fitting.
Could very well be a ten cent part put together by a five cent brain.
It happens.
Doesn't look too tough or expensive to fix unless you make it worse. Not being a butthead, just saying because I know from first-hand experience.
YouTube is an amazing resource
/ Help pls ! LSXJ2025H hydralic fitting leaking #13
I would say looking at your pictures that you have an JIC male to SAE o-ring male fitting on your loader cylinder;
the hose is a JIC female the fixed nut on the fitting is to hold your backup wrench on while tightening the swivel part.
/ Help pls ! LSXJ2025H hydralic fitting leaking #14
:drink:
/ Help pls ! LSXJ2025H hydralic fitting leaking #15
Usually those are used so the 90 can be clocked wherever it is needed, then you hold it still and tighten the nut which seals the packing to the smooth area between the inner and outer threads and the bung on the cylinder.
Make sure the packing is in that non threaded area just like the picture shows. That packing won’t seal again the threads of the fitting.
I install a lot of these type mil-spec 90s. Usually I see a recess cut into the bung where the packing sits with a Teflon washer between the nut and packing. When tightened correctly, the packing and Teflon are not visible and that prevents the packing from being blown out.
Make sure the packing is in that non threaded area just like the picture shows. That packing won稚 seal again the threads of the fitting.
That's what I have,,,it wasn't leaking at the O ring nut end rather where the hose connected to the 90... it doesn't seem to be leaking now as I thightened it but if it does again do I need to replace the hose or the 90 ??
/ Help pls ! LSXJ2025H hydralic fitting leaking #17
If it starts to leak again, you could disconnect as others have stated. If threads are goobered up replace both the fitting and the hose. Fittings and hoses are pretty cheap considering many other parts.Just remember those hoses are under extreme pressures and you want to protect yourself at all times. If it starts to leak again, make sure to shut down the motor and rotate the joystick to try and release all pressure from the system. Even then I would wear a face shield to protect me when looking into the problem up close.
/ Help pls ! LSXJ2025H hydralic fitting leaking #18
If you look at the fitting, you have a rounded nose/male end that seats into a matching female end. Metal on metal seal.
Don't over-tighten it or you might booger it up. Then it won't seal.
If push comes to shove, you can sometimes put a very fine emery cloth on the male end and gently clean it up. You are not machining it, you're cleaning it. If it's burred or grooved, just replace it and get it over with.
Sometimes, because of the tension on the hose wanting to 'unwind' the fitting, you might have to put a little more torque on it, just be careful.
/ Help pls ! LSXJ2025H hydralic fitting leaking #19
None of the manufactures recommend any sealants be used on those fittings;
that said when I work with them I do use a small amount of never seize on the male treads
of the fitting especially on the hose connection, if I have one that is seeping on the hose connection,
I will lube it and make and break it 3-4 times, quite often that will cure it.
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
(6) 8" X 8" TREATED TIMBERS (A63291)
(6) 8" X 8"...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
