Help please
/ Help please #1
gotrocks
Platinum Member
Phenix City Alabama
B-2910 delivered 8/23/01
I've got a Bush Hog 48" finish mower (three blade) TH 48.
Was working great, had even found some new blades to fit.
Whang! One spindle stopped turning, other two OK.
There are two belts that drive the blades, one belt is broken.
I've searched numerous sites, Bush Hog does not
show this model in their "manual" list.
I will rejoice if anyone can direct me to a source for the manual
with diagram for replacement of the belt and part number.
HAVE A SAFE-HAPPY 4TH
/ Help please
Hello Bird,
Long time no see. Hope all is well with you and yours.
Thanks for this info. I looks like what I need.
Norris
God Bless US All!
/ Help please #5
Even if you can not find a manual, you can take the old belt to a supplier and get a replacement. Can also take the one good belt in to match. Last resort, get two new belts that are a close match. They make different grades of belts, from light duty to heavy duty, etc, with different material through out the belt for strength, and durability.
/ Help please #6
ditto 100% what JJ said.
if like belts.. match the good one and get a pair.
get power belts as they will take the punishment a more can put out.
check here.. may be what you need.. about 4th listing down..
Lawn & Garden & Specialty Belts - Bush Hog - TracParts.com
Item #: A-86326
Rotary Mower (FINISHING MOWER: TH48-01, TH48-02) Quantity in package = 1 DIM A (1): Set of 2 belts REPLACES: 86326
/ Help please
More thanks to each of you guys.
Damifino
Interesting comparison from Messicks link;
83121 Belts, Matched Pair. $62.53 4 In Stock
Looks like "pencil vain you" knows how to put the pencil to you.:D:D:laughing:
Soundguy
Belt, Drive Trackparts.com
Item #: A-86326 Rotary Mower (FINISHING MOWER: TH48-01, TH48-02) Quantity in package = 1 DIM A (1): Set of 2 belts REPLACES: 86326
$20.31
I had already been able to remove the belts and one was still clearly marked "Bush Hog 86326"
Found
Madison Tractor Company
71 Jasons Way
Marshall, NC 28753
828-380-0731 Don order belts 22.46
Tuesday - on my front porch Thursday.
Can't get much better than that.
Thank all of you gents again.
Norris
/ Help please #8
glad you got er going
429860 (A61166)
429860 (A61166)
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 579...
3 Bottom International switch plow (A64119)
3 Bottom...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
