HELP! No glow plugs on a 45KS
   / HELP! No glow plugs on a 45KS #1
Nthorseman
I have an 07 45KS. The glow plugs are not activating. When I try to start at - 10 celcius, all I get is white smoke which I suspect is due to the glow plugs not activating. Anyone have this problem? Any suggestions on a fix? It's a very long drive to the dealer and I don't want to tow the tractor into the local diesel shop if maybe there is a loose wire or something.
Thanks.
P.S. I checked the fuses and they are good.
   / HELP! No glow plugs on a 45KS #2
check and clean up terminals on glow plug wire. I have seen paint block proper electrical flow. Next check the relay, they can get weak and not allow proper electrical flow.
   / HELP! No glow plugs on a 45KS #3
Is the tractor starting and blowing white smoke for a few seconds or is it not starting at all? -10c is pretty cool. Might try turning the key on and then off after the glow plug light goes off 3 or 4 times before engaging starter. This will allow a little more heat in the cylinders before starting which might help. I think some white smoke for a few seconds is normal when it is cold.
George
George, it's not starting at all...just blowing white smoke trying to start.
NY_kioti, I checked the connections they looked good. I'll go and 'dry' them out because sometimes looks can be decieving... How to I test the relay though?
Thanks for the replies.
Michael
Checked my pm...now check yours:D
...and thanks for the suggestions.
2008 Ford F650 XL Landscape Dump (A55272)
2008 Ford F650 XL...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
3PT MIDDLE BUSTER (A52708)
3PT MIDDLE BUSTER...
2026 Hillcrest 14166SPT 22ft. 7 Ton T/A Tilt Deck Trailer (A56858)
2026 Hillcrest...
Heavy Duty 10,000lbs Two Post Car Lift (New/Unused) (A59225)
Heavy Duty...
