HELP! No glow plugs on a 45KS
   / HELP! No glow plugs on a 45KS #1
Nthorseman
I have an 07 45KS. The glow plugs are not activating. When I try to start at - 10 celcius, all I get is white smoke which I suspect is due to the glow plugs not activating. Anyone have this problem? Any suggestions on a fix? It's a very long drive to the dealer and I don't want to tow the tractor into the local diesel shop if maybe there is a loose wire or something.
Thanks.
P.S. I checked the fuses and they are good.
   / HELP! No glow plugs on a 45KS #2
check and clean up terminals on glow plug wire. I have seen paint block proper electrical flow. Next check the relay, they can get weak and not allow proper electrical flow.
   / HELP! No glow plugs on a 45KS #3
Is the tractor starting and blowing white smoke for a few seconds or is it not starting at all? -10c is pretty cool. Might try turning the key on and then off after the glow plug light goes off 3 or 4 times before engaging starter. This will allow a little more heat in the cylinders before starting which might help. I think some white smoke for a few seconds is normal when it is cold.
George
George, it's not starting at all...just blowing white smoke trying to start.
NY_kioti, I checked the connections they looked good. I'll go and 'dry' them out because sometimes looks can be decieving... How to I test the relay though?
Thanks for the replies.
Michael
Checked my pm...now check yours:D
...and thanks for the suggestions.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2017 Chevrolet Impala (A56859)
2017 Chevrolet...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2022 International Mv607 (A55973)
2022 International...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
