Help needed
/ Help needed #1
dclynch
kawkawlin,mi
Rhino International
I have a Rhino 404 tractor, and ever since I bought it I had problems with it running hot. I have replaced the radiator thermostat and just recently the head gasket. The head gasket had a tiny leak but was not gettting in the oil. Since I replaced the head gasket I am having a hard time starting the tractor, and I am not sure I am calling this the right name but the de compression lever doesnt feel right when I use it when starting. Before it was tight and you felt resistance and about a 1/4 turn was all you had to turn it now I have to twist it just about all the way around before I feel the resistance and when cranking the motor does not sound like it used to. I have pulled the valve cover off and verified the rod is connected correctly. Any ideas?
Woods RM59 Finish Mower (A62613)
Woods RM59 Finish...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2015 C&M TRAILER 14 ENCLOSED CARGO TRAILER (A65643)
2015 C&M TRAILER...
Welcome to the Ranch Metal Sign (A65583)
Welcome to the...
