Help needed with my computer settings.
/ Help needed with my computer settings. #21
I am using ie6.xxx but do as edie do.. i like multiple pages .. etc.
Guess when i get 7.. I'll be re-learning stuff!
soundguy
Once you start middle-clicking, you'll never go back! Also, as was suggested, firefox is safer (no activex contols) and you can install all sorts of add-ons.
/ Help needed with my computer settings. #22
Edie,
You may want to look at how the Taskbar is set to be used IE Cascade, Side by Side, Stacked. This could be effecting the way it is displaying. Right click the task bar and have a look
/ Help needed with my computer settings. #23
Unfortunately i visit and have to interact with a few govt sites that will only work with netscape or IE...
soundguy
/ Help needed with my computer settings. #24
soundguy
I hear ya. The place I work for has a time keeping website that ONLY works with IE. I found an addon for Firefox that lets you open pages in a Firefox tab in an IE "container". Essentially running IE inside of Firefox.
/ Help needed with my computer settings. #25
Hint, middle-click (with the roller) on a link, that will open it in a new tab in the background.
Nice tip rcrcomputing, I had set IE to open links in a new tab but the wheel click lets me keep reading while the link opens. Thanks;)
/ Help needed with my computer settings. #26
soundguy
I know your pain Soundguy, I used to have to work with WebCM (govt. construction reporting program) and after I loaded IE7 everything went sideways fast. Its was a pain to undo everything back to IE6. I'm so glad WebCM is dead...more wasted tax dollars.
/ Help needed with my computer settings. #27
Well, I learned something new myself. I've been right clicking, then clicking on "Open in new tab"; didn't know about the wheel click, except to scroll up or down.
/ Help needed with my computer settings. #28
Make welfare as hard to get as a building permit
I love that one.
there are alot of things that should be that hard....
soundguy
/ Help needed with my computer settings. #29
Eddie,
From the sound of it I use a browser much like you do. I have 9 Firefox instances open at the moment. I do this all the time. I do use tabs but I like to have related websites in the same browser.
My laptop has 2gb of RAM which helps. On the laptop I have Firefox and IE. Sometimes you just have to use IE. I have an IE instance running as well. But Firefox is where the work gets done. My home system has IE, Firefox and Opera. :D You don't have to have just one browser. :D I put on Opera to play around with. Firefox is what I use 95% of the time at work or home.
Later,
Dan
/ Help needed with my computer settings. #30
Let me make another suggestion. You probably could use dual monitors.
Once you get a second monitor you, will never go back and Windows XP makes using dual monitors very simple. I have two Apple LED 24" monitors.
/ Help needed with my computer settings. #31
:D This is an excellent suggestion. Though an expensive one. :D:D:D When we bought a new PC this year I was going to get two monitors. But figuring that I would have to buy a new video card to support the second monitor I ended up buying a 24inch display instead of two. The WIFE looked at the smaller 22 inch display and like the 24 inch better! :eek: So I obeyed SWMBO. So far the 24 inch display works fine. I hook my work laptop up to it when working from home. In the office I use an external display plus the laptop display. Two displays makes things a lot easier. Two LARGE displays are even better.
Two 24 inch display's is the cats meow. :D:D:D
Later,
Dan
Hays LT1 Tender (A61307)
Hays LT1 Tender...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
