Buying Advice HELP NEED TRACTOR ADVICE
/ HELP NEED TRACTOR ADVICE #1
FIN1977
KUBOTA B3300HSD W/R4 TIRES, FEL, HYDRO @ $15950 OR THE KIOTI CK 30 W/R4 TIRES, FEL HYDRO @ $ 14200.
ALSO HAVE A PRICE ON DK35 KIOTI, R4 TIRES, HYDRO, FEL @ $18700
WE HAVE A SMALL FARM TIRED OF RENTING. WOULD LIKE TO OCCASIONALLY USE A FENCE POST DRIVER. ALL COMMENTS APRECIATED.
/ HELP NEED TRACTOR ADVICE #2
:welcome:Did you try to drive and compare to each other? They all sound big enough to do what you need. You probably could rent attachments that you wouldn't use all that much. I would advise you to try each out and check the dealers reputation for repairs and warranty support.
/ HELP NEED TRACTOR ADVICE #3
Either one that you stated will do what you need to get done, I agree with Wacky you need to go yourself to look and sit and drive.
DevilDog
/ HELP NEED TRACTOR ADVICE #4
as said go drive the tractors that your considering,an see wich 1 best fits you.personally id go with the kubota tractor.but thats just me an my thoughts.
/ HELP NEED TRACTOR ADVICE #5
Can't beat the advice given so far. The B3300 has quarter inching 3-point and I "believe" the Kioti has position control. If it does that would put me on a Kioti or something else with it.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
F-150 4WD (A63689)
F-150 4WD (A63689)
7102 (A61567)
7102 (A61567)
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
