Help my grapple won’t close.
   / Help my grapple won’t close. #1
homedad
central/ se michigan
Kubota L3130DT
I just bought a used ck 3510se/c. The previous owner has hydraulic lines running to the loader. He had a snow plow that has 2 cylinders for angling the blade. The lines run to the rear hydraulic ports. I have a new grapple mounted and it only opened but won’t close with the lever C D next to the seat. Any idea what’s going on? What does lever A B do?
   / Help my grapple won’t close. #2
I think each tractor can be set up differently, so maybe they are connected to the front of the tractor, but those are normally connected to the rear remotes. For a grapple I think there is normally a third function joystick set up for the front end... Not an expert so take with a grain of salt.
   / Help my grapple won’t close. #3
Looks like you have two sets of rear hydraulic ports, also known as rear remotes.
One lever controls one set, let's say A and B.
The other lever controls the other set, C and D.
There should be stickers on the tractor saying which letter corresponds to which rear ports.
Also, you want your hoses connected to the same valve, being either A and B or C and D. Never A and C or B and D, etc.
Thanks for the replies. I believe the main issue was my inexperience with hydraulics. I got it working now and am certain that there was pressure in the lines and I never had the lines properly connected. The bracket that secures the connections was obscuring my view of the connection.
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2007 Deere 650J LGP (A53314)
2007 Deere 650J...
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
1996 Timpte 46ft Hopper (A55315)
1996 Timpte 46ft...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55852)
2004 Pierce Tilt...
