Help...my cub cadet won't move??
   / Help...my cub cadet won't move?? #1
swollen
Salisbury, NC
Cub Cadet LT1042
I've got a cub cadet LT1042 series 1000, & it's got atleast 60hrs. on it. Was mowing and the back wheels just seemed to lock up. -now, this has happen before, & I moved that engage/disengage rod on the back & this time it doesn't work for me. The lever that-that rod moves back n forth, is there suppose to be a spring on the top of it, there's a hole there, to hold it back?, cuz I can pull back on it and turn the wheels.
Does anyone kinda know what I'm talkin' about...
   / Help...my cub cadet won't move?? #2
You are talking about that lever by the right rear wheel? You pull back and down to lock it and it allows the rear tires to free-wheel? Not sure why your rear wheels are locking up while you are mowing. Still under warranty? Try the sister board lawnmowerforum.com may get more answers there.
   / Help...my cub cadet won't move?? #3
Check your brake. If you look by the transmission by the right wheel there is an external brake set up that sometimes gets sticky. That would be the first place I would look.
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
2005 JOHN DEERE 310SG BACKHOE (A60429)
2005 JOHN DEERE...
208315 (A58376)
208315 (A58376)
26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
26ft T/A Dovetail...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
