Help- MF1010 won't move
   / Help- MF1010 won't move
Finally the answer....
Sent the 1010 hydro to the shop.(MF dealer)
Problem was caused by a growing mouse nest inside the clutch housing.
Working the pedal back and forth would push enough of the stuff out of the way and allow clutch travel.
However, since the tractor would sit as much as a month at a time, the critters would fill the space I created with more nest until eventually the housing was packed so full and hard that the clutch woudn't travel.
Dealer had to split the tractor and while in there replaced the clutch.
Very expensive.
Watch out for the critters, especailly if your unit sits for weeks at a time giving yhr rodents time to rediscover and settle in.
Dealer suggested " dryer sheets" or even better a mint concentrate on cotton balls.
   / Help- MF1010 won't move #22
OUCH!!!! at least you found the problem and now know what to do as preflight check before driving it.:)
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2013 Dodge Journey SXT (A50324)
2013 Dodge Journey...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2008 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2008 MAGNUM...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
