Help Me Design/ Build a Shop
   / Help Me Design/ Build a Shop #221
I really like the color of your shop.
Why did you make the doors two different sizes?
Storage racks planned along the left wall would make the larger door pointless.
As for the color... we live next to national park land, and wanted the building to cause confusion about our road being a maintenance area... ;)
Actually, it's so the building is less visible from the paved road... it blends into the woods nicely (probably why NPS uses those colors)...
   / Help Me Design/ Build a Shop #222
Fiesta Concrete is in the shop....
The doorway was 12' 4" and the truck was 13' 2", so... they dug a hole in front of the 12' opening....
This is not what I envisioned storing inside the shop, but..... it does give a good point of reference for the overhead clearance.
Took two trucks (20 yards) of fiber reinforced cement, with just enough overspill to leave a 2x10 "ramp" at the left door opening. There's hardly any gravel under it, so that's probably just going to be broken up later this afternoon for the gravel....
   / Help Me Design/ Build a Shop #223
Why didn't you use rebar?
   / Help Me Design/ Build a Shop #224
It's fiber reinforced concrete, which the builder says doesn't need rebar on a 4" slab. Heaviest moving load will be the F250 and the Kubota.
   / Help Me Design/ Build a Shop #225
I'm sorry to hear that you builder said that. All concrete needs rebar. Fiber helps to a small degree, but it does not replace rebar.
   / Help Me Design/ Build a Shop #226
Well... that's how they pour house slabs here as well -- rebar in the footers, but the slab itself is just fiber concrete. We also don't have expansive soil or deep freezes here, which might be a mitigating difference.
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
Tank Only (A59076)
Tank Only (A59076)
Forklift (A59228)
Forklift (A59228)
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
