Help Me Design/ Build a Shop
   / Help Me Design/ Build a Shop #181
Looks like you already have lots of suggestions on the shop build. I'm in the process for one for my son; I've already had mine built several years ago.
Price for just the metal building was ~$50K. Foundation and electrical will run about the same.
My only suggestion would be to classify it with the County as a 'barn'. Much lower tax rate!
   / Help Me Design/ Build a Shop #182
Great thread. I'm having a 30x50x14 shop put up by Summertown Metals, with material arriving Friday... should be up by end of the month. Was approx $37K including the slab. We are in unincorporated TN, so no permit or inspection for a pole barn.
Concrete slab will be poured after the structure is up. Putting sleeves into the slab to run water at some point, and 3" conduit for electric service later. Someone here convinced me to add two floor drains along the center line.
Added an open 12x50x12 lean-to that will be gravel for all the same reasons mentioned by others. Leaving space for a second lean-to on the other side.
Two roll-up doors on the 30-foot face - 12x12 and 8x10. The 12x12 is to accommodate the RV, although it will likely get stored in the lean-to. Man door opening to the lean-to.
On the back wall, I'm planning a small enclosed area at ground level (maybe 12ft x 15) with a loft spanning the entire 30ft width mainly for storage and also to be able to walk onto the RV roof as needed. We have steel trusses, so that the entire pitched area of the roof is available. With14ft walls, that gives us 6-10 feet of overhead space in the loft.
I'm not planning to do more than ceiling fans in the main area. Mini-split for the enclosed space.
   / Help Me Design/ Build a Shop #183
That sounds like a good-sized building with plenty of doors and storage!!
   / Help Me Design/ Build a Shop #184
One of the things I've found to be really handy is an air station on the outside of the shop. Mine has a pressure gauge (so I can tell if the air system is charged) a shut off valve (in case hose has a leak) and then a 50'hose with an air chuck and blow gun. It comes in handy to fill tires and blow out filters and such.
   / Help Me Design/ Build a Shop #185
Yes I wish I had my 2 stage 175 psi compressor outside. I would have it on concrete in a small insulated room with door.
About 5ft x 8ft would be fine plus garden hose storage. I have an air hose reel which is handy for outside.
I should have insulated everything before moving things in and you can't have too many outlets.
   / Help Me Design/ Build a Shop #186
Placing an air compressor outside in an unheated area results in a lot of condensation in the storage tank.
   / Help Me Design/ Build a Shop #187
There's my shop....
   / Help Me Design/ Build a Shop #188
Those trusses are interesting. I've been planning on buying something similar, but I've never seen them built as strong as yours look.
   / Help Me Design/ Build a Shop #189
Summertown does their own fabrication, so these might be from their own shop. I'll ask... they sell materials as well as doing the assembly. I am buying some 24ft 6x6's to shore up an outbuilding that has a sagging floor... they'll come on the same truck as our house did so delivery was more or less free.
My trusses are for the 30 ft span, but their catalog lists up to 40ft on 6x6, and 60ft on 8x8 posts at 10 to 12 ft spacing.
   / Help Me Design/ Build a Shop #190
1 shop, some assembly required... :oops:
Your profile by your name says tractor: none, but you clearly show a Kubota in the pic. Looks like maybe an L series?
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
Case 2390 Tractor (A59814)
Case 2390 Tractor...
1998 PRATT ISO DROP FRAME TRAILER (A59575)
1998 PRATT ISO...
