Help making a new fuel line for the Kubota?
   / Help making a new fuel line for the Kubota? #1
8NLUGNUT
Central Texas
Several Fords, four Japanese tractors
We're going to make a new fuel line for the old L260 this week.
I want to make sure I do it right the first time so it's good for hundreds of hours of air leak free operation.
I have made fuel lines for gas tractors but this will be the first diesel.
I'm guessing I'll be using a combination of some type of flex line and maybe metal line.
1. Is there a specific sealer for diesel fuel line joints?
2. Specific type of flex line? Plastic, Rubber.....
Any hints about diesel lines I need to know to get it right?
Any help is alway appreciated.
   / Help making a new fuel line for the Kubota? #2
I have found that making a diesel line is no different than a gasoline line. Steel tube is such overkill as far as pressure ratings go, but better 2000% too strong than 1% too weak. Just make sure you have the correct ends. On some imported machines I have seen banjo fittings used. There are ways around them. :D I could tell you, but then I would have to kill you. I am running out of places to hide the bodies.
Just kidding, Andy.
I made the new line out of rubber hose and still no luck on starting but at least I know I don't have anymore air leaks.
   / Help making a new fuel line for the Kubota? #4
Fittings will probably be of flair/dbl fl, or compression style.. none of those need sealer. Any male to female pipe fittings, other than a swivel will want some sealer... like harvey's.. or gasoila.. etc..
soundguy
   / Help making a new fuel line for the Kubota? #5
Just kidding, Andy.
The diesels I worked on had banjo fittings. They were metric and the OEM provided an inlet banjo fitting with a 3/8" pipe thread. But in a pinch you could carefully grind off the pressed on hose end to expose a barb under neath. Some 600 grit sandpaper, a flat spot, and some rubbing will touch up the copper washers.
Hope I didn't let the cat out. :D
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
2018 International DuraStar 4300 Dump Truck, VIN # 1HTMMMMNXJH633369 (A51572)
2018 International...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
2012 Freightliner M2 106 Dump Truck, VIN # 1FVACXBS3CHBJ4624 (A51572)
2012 Freightliner...
Curt Receiver Hitch (A51573)
Curt Receiver...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
