Help making a new fuel line for the Kubota?
   / Help making a new fuel line for the Kubota? #1
8NLUGNUT
Central Texas
Several Fords, four Japanese tractors
We're going to make a new fuel line for the old L260 this week.
I want to make sure I do it right the first time so it's good for hundreds of hours of air leak free operation.
I have made fuel lines for gas tractors but this will be the first diesel.
I'm guessing I'll be using a combination of some type of flex line and maybe metal line.
1. Is there a specific sealer for diesel fuel line joints?
2. Specific type of flex line? Plastic, Rubber.....
Any hints about diesel lines I need to know to get it right?
Any help is alway appreciated.
   / Help making a new fuel line for the Kubota? #2
I have found that making a diesel line is no different than a gasoline line. Steel tube is such overkill as far as pressure ratings go, but better 2000% too strong than 1% too weak. Just make sure you have the correct ends. On some imported machines I have seen banjo fittings used. There are ways around them. :D I could tell you, but then I would have to kill you. I am running out of places to hide the bodies.
Just kidding, Andy.
I made the new line out of rubber hose and still no luck on starting but at least I know I don't have anymore air leaks.
   / Help making a new fuel line for the Kubota? #4
Fittings will probably be of flair/dbl fl, or compression style.. none of those need sealer. Any male to female pipe fittings, other than a swivel will want some sealer... like harvey's.. or gasoila.. etc..
soundguy
   / Help making a new fuel line for the Kubota? #5
Just kidding, Andy.
The diesels I worked on had banjo fittings. They were metric and the OEM provided an inlet banjo fitting with a 3/8" pipe thread. But in a pinch you could carefully grind off the pressed on hose end to expose a barb under neath. Some 600 grit sandpaper, a flat spot, and some rubbing will touch up the copper washers.
Hope I didn't let the cat out. :D
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
2010 Ford F350 Super Duty, Super Cab, CM Flatbed (A52384)
2010 Ford F350...
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
2023 CIMC 53X102 REEFER TRAILER (A52576)
2023 CIMC 53X102...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
