HELP L4060 wont start
   / HELP L4060 wont start #1
SandraOpines
Marianna, FL
Kubota GL3560, Kubota GL4060
L4060 ran fine yesterday, went out to start it today and nothing.
No starting, cranking nothing.
Battery seems fine, jump start made no difference.
PTO switch is off
OPS seems fine
All cab fuses are good.
4 larges fuses under the hood are fine.
No codes, all dash lights and indicators normal.
HST pedal is in neutral.
What am I missing??
Hate to call dealer if its something simple.
Thanks in advance!
   / HELP L4060 wont start #2
Does the dash turn on? If not computer or electrical supply.
I haven't checked in a while but I'm pretty sure the dish complains about safety sensors (pto, pedal, etc) being tripped.
If the dash is fine & working, probably loose wiring to the starter relay or a bad relay.
Dash turns on. Will check the wiring to the starter relay.
Thanks so much
   / HELP L4060 wont start #4
on my MF 1540 HST, the range selector has to be in neutral to start. It was out of kilter this past summer (loose nut), so even though it was in the neutral position per the indicator, it really wasn’t. Zi would have to move it around a bit to find neutral and be sble to start.
Not sure if you have the same lever on your tractor.
   / HELP L4060 wont start #5
At the risk of offering a stupidly obvious suggestion, did you depress the clutch?
   / HELP L4060 wont start #6
Operator presence sensor?
   / HELP L4060 wont start #7
You try rocking the hst pedal......
   / HELP L4060 wont start #8
The seat switch will not prevent the tractor from starting unless the PTO or HST switches are active. The dash will report that either the PTO or HST controls need to be off or in neutral once the key is turned to the crank position.
FIXED: Thank you!
It was the wiring to the starter relay connection. We are doing Hurricane Michael cleanup which is just untold debris and somehow the starter relay connection became unplugged. Plugged it back in and voila.
Thank you so much!!!!!!!!!!!!
   / HELP L4060 wont start #10
FIXED: Thank you!
Where is that plug? Something us L4060 should be checking do you think?
2022 Coras Predator Steel End Dump Trailer (A55315)
2022 Coras...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A55973)
2013 Chevrolet...
pressure washer (A55973)
pressure washer...
