Help! L245DT O/P Lift Arm Trouble!
   / Help! L245DT O/P Lift Arm Trouble! #1
MrCom
Hello, I have a Kubota L245DT and the O/P Lift Arms won't lift the implement(Mower). Could I of over filled the transmission? Or is it because of when i took a 25 min. trip in it I forgot to lock the Lift Arms? Or could it be something else?
Thanks!
Josh
   / Help! L245DT O/P Lift Arm Trouble! #2
My 245DT will not lift something heavy such as a mower without reving up the engine above 2000 rpm, then it will lift anything. I use UTD in the transmission instead of 80 weight. Have you ever lifted this mower before and what's in the transmission and is it full? ric
Case 1020 25ft Draper Head (A56436)
Case 1020 25ft...
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2225EB000633, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
2005 Jeep Wrangler 4X4 SUV (A56859)
2005 Jeep Wrangler...
