Help! L245DT O/P Lift Arm Trouble!
   / Help! L245DT O/P Lift Arm Trouble! #1
MrCom
Hello, I have a Kubota L245DT and the O/P Lift Arms won't lift the implement(Mower). Could I of over filled the transmission? Or is it because of when i took a 25 min. trip in it I forgot to lock the Lift Arms? Or could it be something else?
Thanks!
Josh
   / Help! L245DT O/P Lift Arm Trouble! #2
My 245DT will not lift something heavy such as a mower without reving up the engine above 2000 rpm, then it will lift anything. I use UTD in the transmission instead of 80 weight. Have you ever lifted this mower before and what's in the transmission and is it full? ric
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
Pull Behind Wood Splitter (A57453)
Pull Behind Wood...
204158 (A57193)
204158 (A57193)
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
LOT: Better Built Heavy Duty Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Better Built...
1991 International 4900 Box Truck (A55315)
1991 International...
