Help! L245DT O/P Lift Arm Trouble!
   / Help! L245DT O/P Lift Arm Trouble! #1
MrCom
Hello, I have a Kubota L245DT and the O/P Lift Arms won't lift the implement(Mower). Could I of over filled the transmission? Or is it because of when i took a 25 min. trip in it I forgot to lock the Lift Arms? Or could it be something else?
Thanks!
Josh
   / Help! L245DT O/P Lift Arm Trouble! #2
My 245DT will not lift something heavy such as a mower without reving up the engine above 2000 rpm, then it will lift anything. I use UTD in the transmission instead of 80 weight. Have you ever lifted this mower before and what's in the transmission and is it full? ric
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
Deere 317G (A50120)
Deere 317G (A50120)
